Upper Link wont fit
JT_MONEY_2004
Car: 1990 Q45, Pearl
This is my second attempt to install passenger side upper link and i still can get the bolt through. First Upper link seemed to be slightly damaged so i returned for another and this one won't line up either. Anybody run into this? Driver's side installed easily. Could that Arm that the link bolt to be bent? What's that called? I tried lowering car on jack and tilting steering wheel various directions already.Would appreciate any tips so i can retry tomorrow. If not will take into to shop. Thanks anyway.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Presume you haven't confused R with L?
Q451990
Can you see an obvious difference between the one you removed and the new one? I'd hazard a guess that something is mis-aligned on that side from a prior road hazard/curb hit/accident issue.
Heath
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
How far off line? Can you insert a drift pin (screwdriver works OK too) to pull the holes into alighment
