Infinitiguy19 wrote:
My question is when should the bolts that hold the tension rods/upper links be tightened on a Active car. Should the engine be running or not?
As with any rubber sleeved metal bushing, the rubber is taking all the torsional load, so the goal is to minimise stresses by not preloading in torsion.
I'm pretty anal and I don't go to that extreme to turn the engine on. I put the car back on the ground (weight on wheels) and tighten up.
height difference between engine off and idle stable is maybe 1/4 inch on mine (front).
