upper intake removal
camarokid
Car: 1986 Nissan 300zx
1997 Chevy Camaro
1982 Chevy Camaro
1969 Chevy Nova
I've removed all the bolts on the top, the entire egr system, and the braces on the sides of the engine but it still won't come off. is there some bolts on the back I can't see because of all the hoses?
NolimitZ32
maybe its just stuck to the gasket, have you tried prying slightly?
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Before you start prying, did you remove all 8 bolts? Count how many you removed, because there are 7 regular bolts and one weird stud/bolt combo, you can see it in this pic:
Also, did you remove all the coil packs, ground wires, and coolant hoses attached to it?
http://tech.aus300zx.com/Rear_Water_Hos ... ement.html
ThisIsSparTTa
Car: 91 300ZX TT 2+0
http://z32.wikispaces.com/Intake+Manifold+Removal - Double check all of your steps. It's possible the PO may have RTV'd it down rather than using the paper gasket. I did this once when I didn't have a paper gasket. The next time it was a b**** to get off. I ended up carefully standing over the engine and pulling upward. Sometimes some love taps from a rubber mallet can help too.
camarokid
1997 Chevy Camaro
1982 Chevy Camaro
1969 Chevy Nova
t.mcginley.jr wrote:Before you start prying, did you remove all 8 bolts? Count how many you removed, because there are 7 regular bolts and one weird stud/bolt combo, you can see it in this pic:
..... I thought that weird bolt was a sensor or something that didn't go all the way through the intake. thanks....
t.mcginley.jr
1966 Ford Mustang
No problem, I did the same thing on mine
solaire
nope it's just special to hold one of the bolts for the V63000 cover that runs down the middle
