upper intake manifold removal
drftnassmofo
Car: 84 s12 ca18et-TRADED
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
90 coupe KADE swap-SOLD
06 Infiniti M45
okay i have all ten bolts from block to UIM unbolted, egr unbolted, and all bolts from LIM to UIM unbolted...i read somewhere that if you want to remove the manifolds then you should start w/ the upper and then lower..but i cant get the UIM off w/out prying and yes i did pry even though i shouldnt and its just not gonna come off that way w/out breaking something...how can i get it all off??any help is appreciated thanxsam
NISTECH
you dont seperate the 2 manifold peices to get it all off, just undo it from the head and remove the support bracket bolts as well as al the hoses and wiring to it. then it should just come out, if it doesnt seem to want to come off something else is still attached.
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
okay...how many bolts are there on the bottom manifold? isnt there some that are impossible to get to? well they would seem impossible to get to..(im talking about the bolts on the top of the flange that connects the LIM to the block.)
s13sr20chris
does it move at all? sometimes its easy to miss some hoses and get hung up.
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
yeah it moves but the two outside bolts from UIM to block are threaded into the block and it is just a nut that you take off to get the mani off and the two outside bolts from UIM to LIM are threaded into the LIM and are also attached to UIM w/ nuts so the threaded bolts form a 90 deg. angle and won't allow the UIM to come off either one...confusing but i think you may understand what im saying. i wish i had a pic
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
should i just throw all the bolts back in it and buy a fresh rebuilt motor?
NISTECH
I dont completely understand what you are saying. Here is a picture to try to speed up this process
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
these are the four bolts i was sayin that attach to the UIM w/ using nuts. the ones that are in a 90 deg. angle that make it seem impossible to remove the UIM by itself.
s13sr20chris
stud remover
NISTECH
I am failing to see where the problem is, if you remove the nuts holding it to the head, the whole unit should simply slide off the studs and you can lift it out of the vehicle???
NISTECH
a better question: what is stoping it from sliding the upper and lower intake manifold as an assembly toward the passenger fender?
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
well i appreciate the help everybody but i just decided to throw everything back together ....drive the 200sx until i get 300$ for this built kade i found. its already ready for turbo mwahahaa
s13sr20chris
when you have the motor sitting on the floor you should try again just so you know how to do it. you may have to again.
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
yep..i know man, im gonna go to pullapart and get another head so ive got a spare...maybe some porting.. ty for the help
