seang »
https://forums.nicoclub.com/seang-u122444.html
Wed Dec 23, 2009 10:14 am
I guess if they are longer and stick out farther than stock, I don't see how they couldn't reduce camber. But when the front suspension compresses, there will just be more positive camber depending on how dramatic it actually is. Pics would make it easier to see...
I hope your new UCA's have adjustable camber.
Is the lift really worth the trouble? Camber is hell on big tires, and will need frequent rotations or else they will wear way unevenly. On a 4wd, this will put strain on the driveline if all the tires aren't almost exactly the same. This won't be as big a deal with your 2wd, but you still want them rotated for good measure.
Hopefully you can sort it out.
