MetalFab »
https://forums.nicoclub.com/metalfab-u155170.html
Wed Sep 15, 2010 9:23 pm
If it's not sloppy enough to fall apart, odds are the bushings are still good. on my 4x4 the whole setup is mounted on the outside, so it was easy to unbolt and stick in a vice. I should have left the bushings alone because it took a BFH and an act of god to knock those puppies out! Actually, after about 15 minutes with no luck I ended up getting a few pieces of metal and sandwiched one side at a time in the vise. I'd suggest trying to find some kind of pressing tool from one end after you remove the outer nuts and washers. I wouldn't try hammering on the ends though.
