well i mean im not stupid i know that i have other supporting mods in mind i just needed opinions on the turbos and waste gates and manifoldsZ31toZ32 wrote:you cant just upgrade turbos and expect results, there are a whole slew of parts you need that work together with turbos to make a lot of power. time to get out the credit card.
looking to make it a weekend warrior / show car looking to take it to shows and the drag strip. want the power and the looks to go with it but i want power first im wanting 450 - maybe even 600hp ive looked at upgrading the fuel injectors but not sure what size to go to a aem ems as well as other mods the greddy system has got my attention love the look and sound but also want a system that will give me the best performance for my money as well thats what i was wondering what would be the best way to go for power and budget if internal wg are good and easier for a weekend warrior and fir sine cruising around then that might be what im looking for im not wanting a all out drag car just to upgrade whats already there for better performance and some good boost im looking into running 10 - 15 psi 10 during regular driving and 15 for the stripNolimitZ32 wrote:how much power do you want, whats your goal for the car, what do you plan to use it for? These are more important questions to be asking yourself than whether you need internal or external waste gate. And as a general rule you don't even need to worry about externals until you've got a 3071r or bigger on each side, because a 3" downpipes and turbo back will easily support the flow created by the internal.
you need to do some hw, just some reading will help.versatune11 wrote:looking to make it a weekend warrior / show car looking to take it to shows and the drag strip. want the power and the looks to go with it but i want power first im wanting 450 - maybe even 600hp ive looked at upgrading the fuel injectors but not sure what size to go to a aem ems as well as other mods the greddy system has got my attention love the look and sound but also want a system that will give me the best performance for my money as well thats what i was wondering what would be the best way to go for power and budget if internal wg are good and easier for a weekend warrior and fir sine cruising around then that might be what im looking for im not wanting a all out drag car just to upgrade whats already there for better performance and some good boost im looking into running 10 - 15 psi 10 during regular driving and 15 for the stripNolimitZ32 wrote:how much power do you want, whats your goal for the car, what do you plan to use it for? These are more important questions to be asking yourself than whether you need internal or external waste gate. And as a general rule you don't even need to worry about externals until you've got a 3071r or bigger on each side, because a 3" downpipes and turbo back will easily support the flow created by the internal.
you cant have both of these! if you are starting from square one, 450hp will cost you about 8-10k. intake 3k, exhaust 2k, fuel injectors 1k, new clutch 500, new plugs 80, boost controller 500, chip 100 will get you to 400whp. you could get the 50 more with bigger turbos 2.5k, but then you run into upgrading more stuff while the engine is out. that doesnt include maintenance to get it running right before you start bombing cash into it. 600hp i dont even want to think about.versatune11 wrote: best way to go for power and budget
i decided to go with forged internals all new valves lifter ect. as well as bigger pistons and better rods and bolts as of turbos i settled on garret t2871r's with greddy 3 row fmic and intake with hks turboback system along with injector dynamics injectors and aem ems system with uego wideband and hks bov's and other parts . theres a guy i found with a fully built motor running upgraded turbo parts and tuned with garret t28s at 20 psi made 591 whp i was impressed lolDTRUONG9 wrote:to make things easy...jwt 700bb at 15-17 psi will get you around 450 rwhp with minor bolt on. simple list of stuff you need. go to z1 and check out their power packs this will give you an idea of the mods needed mike smith manifolds are not included in the list. then you can decide what you want and what you need. z1 turbos are a bit different then Jim Wolf. if you want turbonetics good luck cause its gonna be custom=a butt load of money for fab. or Greddy TD05s=4-5k
http://www.z1motorsports.com/index.php?cPath=6_343
that's a lot to digest, the greddy 3-row fmic isn't the best solution, get aspec massives or the tdm fmic if you can.versatune11 wrote:
i was just asking and recommendations to see the quality and opinions of other parts that i was looking to getvulcanrush wrote:that's a lot to digest, the greddy 3-row fmic isn't the best solution, get aspec massives or the tdm fmic if you can.versatune11 wrote:
two, the ID fuel injectors are great, but they're not bolt-on, you have to get either bde (recommended) or winfactor fuel rails.
are you sure you're ready for this kind of project? you were asking basic questions such as what manifolds to get, and now you're doing a monster build.
