Upgrading the turbo on the SR20DET
msaskin
Car: cars, computers, skiing, mountain biking
The calculation to find "new" injector size based on higher pressure is as follows:
sqrt(new pressure/old pressure) * old flow rate = new flow rate
So, assuming 370cc injectors, running at 80psi instead of 40psi, you get:sqrt(80/40) = ~1.4141.414 * 370 = 523.xxx
So, your 370cc injectors are effectively 520cc injectors at 80psi.
~matt
Phax
Car: Control dynamics
NY S13 SR wrote:Stock injectors / MAF / ECU making 340rwhp? How's that done?
___________________Jeff Holdenhttp://www.heavythrottle.com
I won't believe it until I see a couple of dyno charts, dated a few months apart.
S13 King
Car: cars, performance, girls
wow, this was some great insight guys. However, I've settled on the CTC kit for the SR20DET. However thanks for your suggestions, and insight.
240sxDreamer
dang 400 hp...a lot of power to be used "reliably". I have the gt2540r dual ball bearing turbo .86 A/R , haven't dynoed my car yet...
what do u guys think of a 300 hp daily driver. Would it be reliable? prolly 250 changing the boost a bit and upping it whenever i need to. Sounds perfect for the streets lol
I don't need.. 400 horsies...
pampadori
Car: 91 Nissan 240SX coupe
i think 350whp can be very reliable for a few years. more maintainence would be required as with any modded car. Shaun
msaskin
240sxDreamer wrote:dang 400 hp...a lot of power to be used "reliably". I have the gt2540r dual ball bearing turbo .86 A/R , haven't dynoed my car yet...
No offense, but if you only wanted a 300hp daily driver the GT2540 was a really bad choice in turbos.
You can make that 300rwhp very reliably with a T28 and have amazing spool. Using a GT25 to only make 300hp is like having a built head to rev to 9000rpm and never going higher than 5000rpm.
~matt
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
pampadori wrote:i think 350whp can be very reliable for a few years. more maintainence would be required as with any modded car. Shaun
bart and i made it home safely with jays SR... even with all those retarded truck drivers on 81!
