Jemdawg »
https://forums.nicoclub.com/jemdawg-u48609.html
Mon Oct 23, 2006 3:40 am
The speakers in the SL were 6-1/2" 10W 2ohm Blaupunkts. I believe the S trim has Panasonic speakers, because, correct me if I'm wrong, but I believe Panasonic makes all of the stock (non-"premium", non-bose, non-rockford fosgate, etc.) speakers for Nissan. With that being said, the housing and the depth should all be the same as the SL trim, and therefore you can go by my rule of thumb that the negative lead is the lead facing the front of the car. Test this, of course, using a 14.4v or so battery from a drillgun. You will have to cut the wires, but if you plan on replacing the speakers, you have to anyway. If the polarity is correct, meaning that if you have the positive lead on the positive terminal of the battery and vice versa, the speaker will pop outward, if not it will pull in. If you have any other questions, feel free to ask away.
P.S. You will need a spacer to mount new 6-1/2" speakers, if you prefer, you can build one yourself by conventional means, or find one similar to the housing Nissan uses at a local car audio shop.
