Hi all, so im running r34 turbo's on my r32 gtr. build engine (low comp forged pistons, crank..), cams, r33 5spd, haltech ecu, 1050 injectors, audi r8 ignition, AMS1000 unit.. etc etc,, all supporting mods to push higher hp
wastegates alone im showing 8lbs, so off my rule of thumb i should be able to push around 16psi until i break the springs - mechanically speaking.
Wondering if im safe to push more on these (i would imagine so but not sure) or if i can upgrade the wastegate spring or just upgrade the wastegates themselves. the HKS units are only a little over $300 for the pair iirc ? which doesnt seem bad.
My goal isnt much, 500-550whp, shooting for low to mid 20's psi outta the turbo's. i think im totally capable of this
why not more with the mods? want to keep it reliable and not push any of the parts to their limits... i plan on driving it a lot / pretty regularly so i'd like everything to last a decent time before replacing / upgrading
give me your input on my wastegate and boost situation if you will. THANKS!!
