aj44mc wrote:I have tried searching and have not come up with an answer for this question. Does anyone know if the Sirius Direct FM antenna will work with the S H/U?
I'm thinkin' probably not.
The antenna plug on the Versa won't fit into that Direct FM thing without using an adapter. And it doesn't look like the Direct FM can plug into the stock HU without a (reverse?) adapter.
The best and easiest solution (other than switching to XM which is way better ) is to ditch the stock HU. Your sat radio hookup will be a lot simpler, and it will probably sound better too.
