whiterps13 wrote:a common misconception is that slotted/drilled rotors help you stop quicker. the only thing they do is help dissapate heat better, supposedly cutting back on brake fade. however, for the price i think they are really a bad investment. get some good brake pads and youll be fine.
Upgrading your braking system won't help you stop quicker 99% of the time... I'm assuming it's working properly. If you can lock the wheels up with the setup you have now then upgrades (other than perfecting the brake bias front to rear) won't stop you any quicker. They'll just allow you to stop as fast as you can with more frequency.
Some good brake pads do gas. Paggid Blues do from what I've read. So slotted or cross drilled rotors will be benificial with them... and almost neccasary if you are braking hard and often. Assuming they do gas. I haven't found any real proof one way or the other just some companies saying they do who might just want to sell more rotors. They don't claim this on any of their other pads though (even ones in the same price range and class) so I'm tempted to believe them.
Juujai wrote:pad compound is what causes faster braking times.
fatboy wrote:not just pad compound but rotor compound as well. coefficient of friction is what makes braking better
X to Zero times are a function of the friction between your tires and the road.Pad compound effects what temperatures your brakes will work the best at as well as pad and rotor life.
You might be able to shave a few hundreths of a second off by increasing how fast your brakes reach full clamping force.
