Here's starting to gather bushing and related parts to upgrade the standard base 90-96 (G50) to use anti-sway bars from a Q45a - active suspension model.
Good information on this topic is available at
http://www.q45.org
I would like to post recent part numbers for finding the Energy Suspension (poly) bushings and related parts for the forum.
Here's an idea I recently learned about (from Elwesso) that I want to share with the group.
1) On the front -- use 28mm anti-sway bar with new OEM bushings.
2) On the rear -- use 20mm anti-sway bar with Energy Suspension (poly) bushings.
The idea is to balance anti-sway resonse as much as possible between front and rear.
I'll post updated part numbers for the forum as I gather the information.
Feel encoraged to jump in on this thread and share your thoughts and experiences.
Thanks,
Craig
post1690182.html?hilit=spring%20diameter#p1690182
