Turbon8er »
https://forums.nicoclub.com/turbon8er-u35121.html
Thu Jul 11, 2013 8:00 pm
^ exactly what he said. replace tiny wires, build front boxes. Twisting your new speaker lines will also help reduce noise traveling.
you can also use metraonline.com for parts/size, just pay attention to the unnecessary "Universal" parts that come up.
As far as speakers go, there are lots of decent sounding setups, but something i always recommend to folks is to get SOFT or Silk dome tweeters. They reproduce sound much more naturally than a harsh Mylar or Titanium/Aluminum tweeter. I have a pair of Vifa xt25sc90 -04 tweeters to run upfront. I put a pair in my 240 and they are absolutely phenomenal!!! I've heard notes in old songs that i never noticed before! They are 4 ohm and will replace the included tweeter on nearly any component set. I have a pair to replace the already silk domes on my Kicker QC6.5's ($500 components) if that tells you anything. At $50ish a pair, they're not cheap, but TOTALLY worth it. They are a high-end home theater speaker that goes up to 20khz and the detail is amazing. Vifa makes many, many types of speakers, all top notch, but i chose these for the Waveguide and directional clarity, which also means they need to be aimed at the listener for the best detail.
Another tip is to keep your cone-type material the same across your mid-ranges (and tweeters especially). A polymer cone sounds different than a paper cone and a carbon/kevlar cone. Some people may not notice it, but if you have a discerning ear, you probably will.
