Before I intercool the KA this spring and have all new piping fabbed up, I may upgrade the compressor on my T3 super 60 to a T4 (or T04E, or whatever bolts up to the T3 turbine), and I'd like to know exactly what's involved in doing this.
I want to keep the T3 turbine because I like how its low .48 a/r allows really quick spool up and beautiful throttle response; plus, I don't want to change the turbo altogether for fear of the downpipe not fitting (and I just spent a lot of time a month and a half ago re-fabbing it).
So my question is:
a) What is involved in changing out the T3 compressor (.60 a/r), including both the housing and the wheel for a bigger T4 compressor or T04E compressor? Obviously I'd have to remove the turbo and unbolt the compressor housing, etc, but how do I actually change the compressor wheel? What's it held in by? Do I need any specialized tools to do it? I'll probably have the assitance of my dad, who's rebuilt turbo's before, but I don't want the upgrade to be a nightmare. I know the limiting factor of my turbo is the compressor wheel and the fact that it can't flow that much air; I just read a post by erich saying his built ka @ 11 psi with a T3 60 trim (almost identical to mine) only had 222 rwhp--and I want at least 20 more whp than that @ only 10 psi.
b) will upgrading to a larger compressor create more lag? Will it increase the RPM at which I achieve full boost and hamper throttle response?
c) I know there's different size T4's out there, and I'm not sure how big I should go. I'm going to be running 10 psi with a JWT ECU, 370 cc injectors, PDM stage II cams, walbro 255 lph fuel pump, intercooled, etc etc. I'm looking to maintain a broad powerband but also make some power up top. Currently my problem is boost drop-off past 5k rpm, which can be attributed to a variety of factors, perhaps even my MBC, but changing the compressor I believe will definitely help to gain some psi up top. Also, are T04E upgrade kits available that bolt right up to a standard internally wastegated T3? If so, where? Would a T04E 50 trim be better than a T4, say this one:
http://cgi.ebay.com/ebaymotors...09814
Any info would be appreciated, thanks.Marc
