Upgrading 94 Q45 head unit
spunkrat
Car: S13 Silvia and Infiniti Q45
Hey guys
I have done a quick search and came up with a few answers, but I am just wondering how hard it is to upgrade just the headunit and leave the Bose speakers in place? I am happy with the speakers, but my car doesn't have the CD changer, just the radio and tape player, and I would like to listen to CD's. I have purcahsed a double din Kenwood DDX5032 DVD. Am I correct in saying I need some kind of converter to change the signal from 4ohm, to 2ohm? Or am I way off? Does anyone know of any part numbers for what I need?
Thanks in advance!Brendon
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Too bad you already purchased a new CD headunit (although not bad if that's the one you wanted). There are OEM Bose CD alternatives. My car has a late-90s Pathfinder/Q41 headunit with both tape and CD. It's a factory Nissan Bose HU so it is a direct replacement for the Q HU. It also interfaces with the stock Sony CD player, but that's not an issue for you I guess. The same headunit came in a few different Nissans and Infinitis from the late 90s.
The one I have is exactly like this one but lacks the "clock" button which is fine as the Q has the separate clock.http://cgi.ebay.com/ebaymotors...ivers
Rex
Car: None
An adapter is required to swap in the unit MoD has, but if you find one with the Dolby DNR button on the lower right hand corner (J30 & G20's) it's plug and play.
The adapter is a $15 Nissan part.
Search some old posts by me and you'll find all the info on it.
BLACKonBLACK98
Car: Q45, LS400, STS-V
the correct way to replace a bose system is to replace it speakers and all.
that being said, you can wire in an aftermarket hu with oem speakers. since the bose amplifiers are used to seeing a low level input and you are replacing it with a high level what will happen is the system will get louder a lot sooner, so be careful with the volume control.
if you are any kind of concerned with sound quality speakers should be replaced and external amplifiers used.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
BLACKonBLACK98 wrote:the correct way to replace a bose system is to replace it speakers and all.
Absolutely. The adapters are a compromise, and most are a poor compromise.
Either stick with the original design, or replace it all, including wiring.
lildwell
Car: 1995 Infiniti Q45a
Either stick with the original design, or replace it all, including wiring.[/QUOTE]
I agree. Im dealing with a Q were the original owner replaced the HU and speakers with the original wiring. Its a mess.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
maxnix wrote:Absolutely. The adapters are a compromise, and most are a poor compromise.
All the mechanical work I enjoy, however nothing will I enjoy as I used to installing high end car stereos as an MECP installer.
I find nothing more satisfying than dissecting the entire interior of a car, without so much as a scratch or broken clip, replacing with nice clean new heavy gauge wiring, running some beefy 2awg power cables, wiring up a few caps, fiberglass molded panels in the truck, calibrating speaker settings, tuning amplifiers, stealth installs with hinged secret doors, the sweet smell of a summer night's mist...
Ah, those were the days!
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
I could not have said it better myself, with one exception: I never got MECP certified. I failed my test by 2 points and never took it again. That's why I sale parts and have the P2 ASE certification.
spunkrat
Sorry guys, I think you missed the part where I have already purchased a new headunit, and I don't want to replace the OEM speakers because they sound good enough for me.
From my research the is something that can be wired inline with the speaker to convert the signal coming out of the aftermarket headunit to the signal that the amp/speakers need. I just want to know if anyone knows where I can get said part.
Just so that it is clear, I am not some audiophile who wants to build an amazing SQ stereo. I want an CD/DVD head unit and the original speakers.
I know there are better ways to upgrade the stereo, but this car is just my nice, daily driver car, I already have a car that I spend money on, hence why I am not replacing speakers that already work fine.
If anyone can actually help with what I need help with, I would really appreciate it.
ThanksBrendon
TellarHK
Car: 1994 Infiniti Q45
1995 Jeep Wrangler
1990 Nissan 300ZX
My understanding is that if you really want to throw in another head but keep the original speakers, is to go with one of these:
http://www.crutchfield.com/p_1....html
I'm considering a CarPC at some point in the future, and will be picking one of those up sometime in the near future to make sure I have it when I need it. The Bose systems are definitely not perfect, but if you don't have to run new wiring, don't.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Ok buddy.
The link that TellarHK put up is the part that you need. I bought one and have it somewhere in my garage if you want to buy one. I took it out because it sucked. I had my Alpine CD player w/ the direct XM and wanted it in the Q. I bought that piece of crap adapter and installed it w/ the Alpine. I turned on the HU to do a level test to make sure there would be no distortion. When I turned it on the volume was half way up (default for he HU). It was distorted like crazy. I checked the levels on the Integration Adapter and the were 1/4 the way up. I turned the volume down on the HU and the levels down on the IA. With the levels all the way down, I could get the radio to 20 (halfway) with bass turned down. At that volume you could barely hear the music with the windows up and you could not hear the music at all with them down. I rocked that for a month or so, then replaced it with my stock HU and the iPod connection that plugs into the factory changer (custom).
There's your answer bro.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Geez, I am coming to visit you when I install my AVIC Z3!
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
I have an "Integrated Peripherals" brand line output converter for the Bose speaker system that I use with my aftermarket deck. Its just like the Scosche one but like someone posted above, does not distort the sound at all and sounds better than the Stock HU ever did.
spunkrat
Thanks for the info mate!!
I ended up taking it to a shop and telling them how it worked, and he just put it in without the converter. I was a bit annoyed when he told me that, but it doesn't really matter that much, it just means the volume doesn't need to be turned up very loud.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Kiven422 wrote:I have an "Integrated Peripherals" brand line output converter for the Bose speaker system that I use with my aftermarket deck.
Can you source that part? My understanding was the Skosche was mediocre, at best.
aces805
Car: 1994 Infiniti Q45t
Quote »I have an "Integrated Peripherals" brand line output converter for the Bose speaker system that I use with my aftermarket deck. Its just like the Scosche one but like someone posted above, does not distort the sound at all and sounds better than the Stock HU ever did.[/quote]The Kenwood head unit in my car sounds absolutely great with the stock Bose speaker system.
Shop used this adapter:
Like I said, sounds very good. I listen to rock, rap, Sinatra, jazz, top 40 etc...each genre has great sound quality.
A good adapter is your friend, when running an aftermarket head unit with stock Bose speaker system.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Here are the installation instructions:
http://www.pac-audio.com/PACPr...0.pdf
Part Number: AOEM-NIS2
Product OverviewAmplifier integration interface for Nissan vehicles
Product Description OEM-1 with a vehicle specific harness plugs into the vehicle's wiring and offers a 4 channel RCA audio output for adding aftermarket amplification. Provides full range audio output 20-20,000Hz. Audio output level is controlled by the volume of the factory radio. Product Features *Plug in installation retains factory wiring integrity *Linear 20-20,000Hz sound reproduction based on input signal *4 channel RCA output *Amplifier turn-on trigger wire *Transformer isolated for optimal sound and performance
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
According to the site, what is required for a 1994-1996 G50 is the ROEM-NIS2
Product Description Replace the factory-installed Bose radio in select Nissan and Infiniti vehicles and retain the function of the factory amplified audio system without cutting the factory wiring. Includes OEM-1 interface and a vehicle specific harness.
Product Features
Plug-and-play installation retains factory wiring integrityTransformer isolated for optimal sound and performanceMaintains correct phasing
Retains the function of the factory-installed amplified sound system
Or, the AOEM for "audio interface" and the latter for "radio replacement".
Sounds llike code, as one wouild not require another interface if one is repalcing Clarion with another same Clarion model.
Modified by maxnix at 1:04 PM 6/18/2009
