Shnitz »
https://forums.nicoclub.com/shnitz-u9027.html
Mon Nov 13, 2006 11:47 am
Hi, I went to get an alignment done on my S13 and found that my ball joints and tension rod bushings needed replacing. I just finished replacing them, but while I was down there, I noticed that the brace that the tension rod bushing sits in is starting to crack. It is this part, I don't know the name of it:
With my tension rod bushings I got polyurethane, since I'm replacing them, I'll just upgrade to better than stock. So, would it be an upgrade for me to get this brace from an S14, 300ZX, etc instead of an S13? I will probably just go to the junkyard for this, the old couple that owned my car before me towed it behind their RV, which is what I believe caused enough stress for it to crack. Also, while I am there I am keeping my eyes peeled for J30/Q45's for the front brakes, is there anything else to look for? For example, are the front and rear sway bars off of any previously mentioned models better than what I have? Thanks.
