Turdferguson »
https://forums.nicoclub.com/turdferguson-u181093.html
Tue Jul 19, 2011 2:36 pm
Posting an update that can possibly answer some questions for others. I finished the majority of my install and lastly want to replace the back door speakers and possibly use some dynamat in the trunk.
For around 400 dollars I managed to install two amplifiers, an aftermarket head unit, buy a 12" subwoofer with a box, buy two wiring kits for the amps, a wiring harness, antenna adaptor, head unit kit, power distribution block, and front door component speakers. One of the amplifiers was ten years old and laying around, so I put it to use. Everything else was purchased brand new through combinations of ebay and amazon. This was also all shipped to an island, so I had to get creative with finding the right opportunities.
A few tips for anyone else doing a similar installation.
If you don't have an old school iron coat hanger to push the speaker wiring through the door grommets, there is room to pop the grommets off the door and car base and encoat the wire in a black plastic sheathe so that it appears professional. Then simply pop the grommets back in using a butter knife or similar tool.
All four door speaker sizes are 6.5 inches and my versa had tweeters in the front pillars. I bought Alpine components and wired them according to the instructions and DID NOT USE FACTORY WIRING FOR THE TWEETERS. I liked the Alpine ones because they had crossovers built in and I didn't need to mount more crap...plus they are high quality for an affordable price. I wired the tweeters directly to the 6.5" door subwoofers and the woofers went to the amp in the trunk via the original wiring, which I joined up behind the head unit. I ran speaker wire from the amp up the right side of the car along with the amp remote wire and both amp preouts. The power is the only wire that went up the driver side of the car.
There is a link to instuctions a few posts above this one that tell exactly how to take your doors apart. I used a butter knife and a spoon because I'm cheap and didn't want to purchase a 12 dollar tool set. Your first door will take awhile but every door after that goes much faster. A butter knife takes off the front pillars extremely well in order to reach the tweeters. You may have to measure the space available for tweeter room, but my set fit in there perfectly.
I drilled a hole just above and to the right of where the clutch would be if I had a manual vehicle. I couldn't fit 4 gauge wire for the amps through the factory grommet. I ran 4 gauge wire from the battery to a power distribution block in the back and then split off two 8 gauge wires to each amplifier. I ran remote wire to one of the amps and simply daisey chained it to the other amp. To my knowledge, it is not worth running a relay for just two amps and this process is faster. My setup works fantastic!
There are plenty of spots in the trunk to find a good place to ground the amps however, for me, the headunit was a nightmare. I have big hands and scraped them up to a bloody pulp finding a ground for the deck. I managed to find one on the left middle portion somewhere and screwed it in. This was one of the most frustrating and difficult parts of the installation and I wished I took a picture of it to show others.
I used black electrical tape for all wire joining with the head unit, speakers, etc... You don't need to use anything fancy but it may be more electrically sound to use fasteners or sodder. I simply don't care and was going for cheapness and speed of install.
I believe I have the SL model of Versa and it came with the 6 cd changer as well as Blaupunkt 2 ohm speakers. This version of cd changer DOES NOT HAVE ANY AMP PREOUTS!!!
And that's about it. The audio is incredibly loud at high volume. The highs make my ears bleed and the mids are screaming. The bass isn't earth shattering like some of the other sound systems I've thrown together but for the price, it's very decent. I also have a huge car child seat in the middle of the back seat ,which may contribute to some rattling or dampening of the bass.
I am running 75 watts rms to each front component set from a Jensen and 150 watts rms off a Kenwood to one Kicker 12" svc in the trunk off of a two amp preout JVC cd/aux head unit. The subwoofer box is probably insufficiently sized for that subwoofer but I'm a family man and need the room. To complete my install, I will replace the back door 6.5" speakers at some point with 2 ohm Infinity's and put some sound deadening in the trunk to help with trunk rattling. Total cost will be below 500 dollars and the overall sound will be pretty close to systems I've spent four times as much money on.
The overall volume gets so loud up front that it makes it very difficult to adjust the gain levels on the amp because I almost have to plug my ears before I hear any distortion. And I'm someone with significant hearing damage from playing sound systems in vehicles for well over a decade. 50 watts rms is probably plenty for upfront speakers and if you have more money to burn, I would recommend using that on more trunk bass, as the backseat seems to absorb a good portion of it.
