Exhaust will not fit. It will, but you'll have Naturally aspirated exhaust on a turboed car which over time will damage the turbo due to back presure. You can replace all those seals and gaskets if you want, but it's not required if you get a good engine. So basically the very minimum you need isEnginetransmissionI say fuel pump and fuel filterMASIgnitor chipRadiator electric fan (unless you get a clip or radiator shroud)IntercoolerAll the fluids Wiring redonea BOV is nice
It's not something you go half assed into, especially if your doing it to your daily driver. Like J-Spec said searchtryswap, parts list, sr20det stuff like that. Also check out
http://www.heavythrottle.com and go to their FAQ's. Other than that, read others posts and try to familiarize yourself with the sr as much as possible. Especially if your going to do it yourself. I'm sure your anxious to do a engine swap, I know I was but going into something half assed is a time old assured way of ****ing up. Hope this helps
