boostedh23a1 wrote:I was thinking about gt2860-5 which you can get for about 1950. If I go single I would probably go with either a raw brokerage manifold or a full race one, which by itself is 1750/2200. And probably run the GT35r or similar. Probably a ~66mm wastegate. So that would add about 2grand but it would be better when I build the rb30...
Honestly I'd go single and be done with it. Get a 6266 T4 if your worried about spool should be hitting full boost ~4200 ish (2.6, 3.0 would be ~3500ish) with easy 500whp + on pump 93.
As for tires I run 275/40/17 ET streets all the time. In 75+ degree weather I'm pretty much 100% hooked in 2nd on most road surfaces. If I do spin its not out of control and is still moving me forward nicely (nothing a quick pedal/slight let off cant take care of). I have 4.08 rear gear now.. plan to switch that to a 3.69 which will I think eliminate almost all slip in 2nd. I do have stiff megan coils which do not help, so I can only imagine a nice set of drag coils would greatly help as well.
My car weights 2940 fully wet, not sure how light your S30 is but can give you an idea.
