USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Wed Jul 16, 2003 4:29 pm
Ok... here is the deal on the o2 housings.....
I bought an SR one so I wouldn't have to cut and weld a downpipe to fit. But ran into a few problems.....
The obvious difference is the clocking of the collector. Its about 15 degrees different.
The CA o2 housing is about 1 inch SHORTER than the SR one.
The CA housing has one opening... that is for the o2 sensor. The SR one has 2 openings, which accounts for the extra length. It has the opening for the o2 sensor, which I think goes into the bottom bung, and the upper bung is for the AIV.
You could use the SR one, all you would have to do is take the bung out of the CA housing for the o2 sensor, put it into the SR housing and block off the AIV with that nifty AIV plug for a 300zx and it will bolt to the back of the CA T25 with no problems. BUT... it will now hang about an inch too low and will have alignment problems with the cat.
I discussed this with Jon once and he said that his T28 actually hangs lower than the T25, which is why his downpipe needs to be shortened.
If you ran a T28, with an SR o2 housing and a 3 inch unmodified SR downpipe on a lowered car.... SCRAPE city.
Best bet is to just modify an SR downpipe to fit the CA housing or just buy a CA downpipe from someplace in australia. Best price I found was a Kakimoto for 500 AUS to my door.... which works out to about 320 bucks minus import duties. I figured a 150 Heavy Throttle downpipe cut and welded by my buddy WAY outweighed a $400 downpipe with almost a month of delivery time.
HTH
Joe
