av8or »
https://forums.nicoclub.com/av8or-u92327.html
Mon Feb 09, 2009 6:48 am
ok.. for those interested, hopefully at this point, everyone knows how to remove their headlights.. sorry i didn't take pictures while i was doing the install..
this is the kit i bought.. it is not bi-xenon, therefore your hi-beam is still halogen.. i have no problem with this as both hids when on are bright enough..
there is a round cover that seals your headlights in the rear, you need to make a round 1" hole... this is important as this is where the wirings for you hid will pass thru.. dont worry, the hid wirings comes with a rubber seal that will fit on the hole you made... anyway, this needs to go...
one thing to remember here is yellow is low beam, red is high, and black is ground.. and this is your igniter / ballast..
the thick rubber on the right contains the wires that connect to your hid, they are colored blue and red and have their own connectors... the one on the left are the wires that connect to your factory headlight wires... there is a connecter that go to the ballast and on the other end is where you splice and cut then connect your black and yellow wires... note.. your high beam which is regular halogen does not need to be connected to the ballast.. they have yellow wires and one connects to the red wire and the other to the common black wire of your factor connection ... (are you cross-eyed yet?)
easy enough? here is where i ended up securing the ballast on the passenger side
any other questions i'll be happy to answer... i'm in the escondido area ( socal ) and the hid kit i bought is in san marcos... ebay seller but allows local pick-up..
Modified by av8or at 12:25 PM 2/9/2009
