rudee023 »
https://forums.nicoclub.com/rudee023-u4970.html
Fri Apr 02, 2004 7:57 pm
Well, the fact that the A/C condenser is yet another obstruction in the flow path of air to your radiator. Air flows through your FMIC, gets heated up in the process of cooling charge air, passes through A/C condenser, gets heated even more and finally gets to your radiator where it has to cool the coolant running through it. I'm not saying you can't get away with a stock rad but I say if you are gonna be running autocross/drag once in a while it's a sound investment to spend the $300 on a Koyo. Especially since it didn't look like you were planning on running stock boost by your list of mods.
