NISMO_RB25 »
https://forums.nicoclub.com/nismo-rb25-u11080.html
Mon Apr 09, 2007 4:10 pm
It will be fine with some good electric fans. The 25 sits close to the radiator making it difficult to setup your fans as pullers. With a thicker radiator the problem gets much worse. With that said what I did was notch the radiator support at the top and bottom, weld in a new bottom support and lean the radiator forward to give me clearance for a Koyo radiator and dual 12inch FAL fans.
You don't need to go to that extreme, but I do have some recommendations.
1) replace water pump, cheap and pretty easy to do while the motor is out of the car. (good time to replace the timing belt and tensioners as well)2) nismo thermostat, cheap and easy3) cooling panels top and bottom to direct air to your radiator.
If you have a redicoulsly thick intercooler like I do, the cooling panels are a must.
Have fun.
