upgraded radiator fan
727G35
Car: 03 Infiniti G35 sedan
i plan on throwong on a turbo and goung to puah arouns 225hp 250tq
i have a 97 2.4 5 speed 2wd.
i was wondering if they sell an aftermarket fan you can just replace your mechanical stock fan with?
or would i be better off removing it completely and running 2 electric fans?
ill probably put a hood scoop for extra cool air if i need to.
i have an auxiliary oil cooler im installing in a few days.
I just want to be 100% ready in the cooling department before i put this turbo on.
any advice for cooling will be greatly appreciated.
thanks
whomadewho
Car: 1997 Nissan pickup
Before starting... Find someone who will be able to reprogram the ECU. Rather doubt the engine will perform well on today’s low octane fuel. May also ? have to change pistons - lower compression? Might? Be easier going with a small block V8? You should be able to find an adapter plate? An older pre emissions engine with a mild cam will easily get you close to the 200 hp.
727G35
im going to get a wideband and SAFC.
I talked to someone that has done it.
Just planning on 5 psi 8 max.
I was thinking a V8 But id like to stay Nissan
maybe a vk56de?
that was pretty quick in the big a** titan
You're not "reprogramming" a Nissan ECU from 1997.
Sounds like you have a lot of planning to do. A DOHC KA will handle low boost with a standalone, but to make any meaningful power, you're doing a full rebuild.
An SAFC is a cheap shortcut, from decades past. Proper tuning requires more than simply modifying the MAF signal. I've been down that road several times. :)
Your fan is the least of your concerns - a properly-functioning stock clutch fan and cooling system is more than capable of handling heat (even here in AZ).
727G35
AZhitman wrote:
Tue Jun 09, 2020 7:15 pm
Im really trying to remove the fan and clutch for more room for a thicker radiator with electric fans. The less rotational mass on the engine is just a bonus. I just figured id keep the stock size radiator if I can find a fan that pulls more air.
ive seen 8 psi on an engine without being built as in not needing to remove the timing chain, actually not even fuel upgrades. Upon disassembly after 3 months or so the only problem was the rings started to expand.
i just want 5 to 7 max so starting at 5 I dont think ill rebuild, just upgrade bolt ons, and check internals after running 5 and turn it up a bit if it seems secure
