upgraded na clutch instead of stock tt clutch on swap?
Re037
Car: 1992 300zx 2+2 NA
was wondering if this would hold up as well if not better than oem tt clutch+flywheel. i dont plan on going crazy hp levels, prob just a stock tt swap maybe 350 hp max. stock tt is rated at about 280~ ft lbs of torque and have read up on some na clutches that can hold up to 350-390 ft lbs. I was wondering if this would work since i dont plan on going for much power over stock. reason is i might be getting an auto tt front clip so i might have to re-use the na manual transmission if i do.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
you can buy an upgraded n/a slutch and if you're lucky it'll hold as well as the stock tt clutch, I highly recomend running the tt clutch
