Mustang guys do this all the time, so there has been quite a bit of trial-and-error done to ensure that certain injectors work with MAF upgrades using the stock ECU or even with an ECU reflash.dg_performance wrote:Im a little new to the nissan world but i figured i would see what you guys think about this idea of trying to avoid ecu tuning with power upgrades.
A rb25det Maf reads 0-5.12V.... and that is based from 0-4423 Flow UnitsUsing the stock 370cc injectors the computer needs no tune since it is all stock!
A z32 Maf reads same 0-5.12V ... but at a differnt flow rate of 0-7546 Units Since the rate of difference between them is .587
In theory "586cc injectors" ( i know they dont make that exact injector size) with a z32 maf could run perfectly on stock rb25det ecu? Right?
The ecu would be basically doing the same math without knowing the upgrades are installed.
If the factory ecu should run the injectors at the same rate of air it sees from the MAF. I think it would be compensating for the upgrades without knowing!
Has anyone done something similar to this?
We basically have the same set up. And all these guys are right, don't expect to beat on this thing as is. It's good enough to drive an put around on but not to romp. I have a JGY top feed fuel rail, Z32 TT ECU and soon a new FP regulator coming in. WAIT UNTIL YOU HAVE ALL THE NECESSARY PIECES TO THE PUZZLE BEFORE YOU DO ANYTHING. RBs are NOT cheap to build or REBUILD. Don't go blowing up an investment.dg_performance wrote:Im a little new to the nissan world but i figured i would see what you guys think about this idea of trying to avoid ecu tuning with power upgrades.
I believe it is either 3 or 6 wires (someone correct me on this) and any TT ecu from 1990+. And you will have to have the ecu tuned for the injectors and maf still. And if you're running gauges, the handheld device for PFC is useless besides for changing things. And unless you plan on pushing the limits of your motor, it is completely unnecessary. Aussies are putting down 600 to 700whp in the forums with dyno sheets on Nistune. If that doesn't tell you the capabilities of the software I don't know what does.dg_performance wrote:So if i got a z32 ecu.... what year z32 ecu should i go for? I got a 96 rb s2. If i am going to go this route i thing nistune would be the olny option.
Or should i save up a little more and buy the apexi power fc? Does this have more tuning capabliities that the z32 ecu? I kinda like that the PFC has the handheld device that i can look at anytime 2 c how things are running.
By going with the z32 ecu i should be able to run the z32 maf i already got with the skyline stock 370cc injectors right? I only have to repin the ecu correct? How many wires we talking about?
