Bluefire »
https://forums.nicoclub.com/bluefire-u7784.html
Wed Apr 02, 2008 11:02 am
Stick with denso or jecs...
With any part you buy it, you really shouldn't consider the few that haven't had problems, but the people that did have problems. Deatchwerks as well as any other injector remanufacturing companies have horrible track records. This includes my own personal experience.
I have yet to see a single jecs or denso injector fail or perform up to my expectations at least within the first 10,000 miles or so. As for redrilled injectors I would say 70% have either failed or haven't flowed up to its supposed flow rating. Not only will you have to buy new injectors, you risk spending more money to retune or in a worse case scenario detonate and have to rebuild your motor.
And even for the few sets that do seem to work out, it still doesn't change the fact that they have horrible spray patterns. This impedes fuel atomization which essentially comes down to you not making the power you want as well as having horrible gas mileage.
There are so many other areas you could reasonably cheap out on to save money, but when it comes to fueling, don't risk it!!!
-Bluefire
