No doubt, or you made a typo. You said you want a stock bore headgasket, but thicker right? Yes 86mm is the stock bore, and stroke aswell. But you "can only find 87mm and 86mm gaskets"? So why are you asking? Unless, you meant 87mm & 88mm? If that's the case, edit your post.climaxsr20 wrote: be more specific.
call jeff at heavythrottle.DrifterProdigy85 wrote:Stock is .8mm
http://phase2motorsports.store....html
click on the linkDrifterProdigy85 wrote:Stock is .8mm
No problem. That's what I'm planning to go with anyway.josephg15 wrote:apexi? ok cool ill look into it...thanks alot.
