Upgraded Fuel
RedHatchback
Car: was a 240, now a cobra, soon a z32 TT
I have a set of Silvia fuel injectors on hand and I was wondering if they would be a direct fitment into the KA fuel rail.Wil I also need to adjust the fuel pressure or what? Thanks
kim
Car: 90 240sx, 97 M3
I think it will fit for the KA24DE since it is side feed
Hijacker
Car: '92 240sx Convertible
'94 F-150
as long as they're side feed. but you will need to inform the ECU that you changed the size of injectors which means you will need either a piggy back computer or a reflash, or a standalone.
RedHatchback
As a piggy back,do you think I should use the HKS Super AFR or the APEXi SAFR?I would just like the opinoin of others.
Nismo_Freak
Car: 89 Nissan 240SX
RedHatchback wrote:As a piggy back,do you think I should use the HKS Super AFR or the APEXi SAFR?I would just like the opinoin of others.
Neither would have an adequate control over larger injectors, you'd need to get a E-Manage or something to that effect.
