What i did is basically took the baking soda and glue method from 240sxtech.com enthusiasts and DIY's and just made a makeshift repair of the vinyl dash of the S13 left hand. I dont know if anyone has posted this, but what the hell you know...
This dash had major cracks in the dry rotted foam mesh adhesive backing for the vinyl. So what i did was mix two part 3500psi rating epoxy that i got from lowe's with baking soda. Couldve and shouldve used talc or baby powder for better sanding capability( feathering better). I want to just say that i believe your actual mechanical & chemical bond might weaken a little bit from mixing both(epoxy and powder) together rather than poured on top of crack fills as they mention in the tech article^; however i have only heard that people say its suitable not professional for a "quickfix". Iv'e even been told to shred fiberglass filler into very tiny pieces and mix it.
After all the sanding and prepping ( wax &grease rem. some laq thinner) I used the Dynapro Rubberized Undercoating on top of the vinyl, thinning it out perfectly is the key to getting it to look just like some immitation vinyl. I just used some medium urethane reducer in it, not enough, I think. Thats basically a max 24hour job- mostly for your epoxy build- and itll look pretty darn close to a dash.
