AppleBonker »
https://forums.nicoclub.com/applebonker-u101518.html
Mon Aug 17, 2009 2:00 am
The Bose amp is nowhere near as simple as running a normal aftermarket amp. All the connections are proprietary.
So let me get this straight, you just have the speakers installed and not the head unit?
Either way, the wiring is insanely complicated. Yes, you'd have to run speaker wire from the trunk to the speaker in each door, as well as to all THREE speakers in the dash and to the rear speakers in the deck. Not to mention the completely new wiring harness that would run all of the cables to the trunk from the head unit. To do this, you'd have to feel pretty comfortable ripping the entire car apart. There is no write up or pics for this. The amount of work needed is generally reserved for people crazy enough (like me) to install systems breaking the multi-thousand dollar barrier.
If this will be your first amplifier install, don't bother. It would be easier to go aftermarket. You're going to spend far too much time and effort on not noticeably improving your setup. This would be like paying someone $100 to kick you in the nuts. There's just no reason to do it. I'm not trying to be mean, but it would take me FOREVER to walk you through this. For as little as you will gain, it's not worth my time (and it's certainly not worth yours). Once again, I'm honestly not trying to be mean, just giving you my honest opinion.
