BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Mon Oct 11, 2004 6:04 pm
I am getting ready to upgrade my SR again, this time concentrating mainly on the valvetrain.
I am looking at some HKS Cams, 256 intake, 264 exhaust but I don't know if I should go with step 1 or step 2. I know step 2 recommends changing valve springs but from what I've read the HKS units aren't good and actually softer than stock.
I don't want to pull the head, so what is the best method to change out the valve springs with the head on. I know to use the air compressor fitting that goes into the spark plug hole, but I've been told that the common spring compressor won't work, and since this is a one time affair (hopefully) I don't want to spend $100 on a new tool. Is there a trick to doing this with relatively quick speed?
I plan to do the springs at the same time I do the cams, so at least I'll already have alot of the stuff in the head out of my way.
My other question, is do you have to remove the fuel rail to remove the injectors, or can they be replaced without removing the rail? Also, are the 300zx injector o-rings (both big and little) the same as the SRs? I've got some 740cc Tomei injectors but I have to install them once I get the car to the dyno which means side of the road mechanics again, so I'd like to get all my ducks in a row.
