Upgrade The Front Door Speakers....
Nissan 350z / Nissan 370z general community discussion forum
Z32 TwinZ
Car: 1991 300zx TT
So im looking to upgrade my sound system in my 2006 roaster. ive been searching for speakers but cant find any that fits the front doors, other than Focal shallow mounts.
What speakers do yall use? Is there something i can modify that will increase the depths behind the door area to fit normal component speakers?
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
check out crutchfield.com. google more.
orangeNblue
Car: 2008 Nissan 350z
there's also a member on here named Broadfield who could help you out. I bought some JL Audio C5 components to put into mine....
Z32 TwinZ
Car: 1991 300zx TT
i figured it out. the stock speakers have a 1" spacer build onto it, when you remove them, the 1" spacer doesnt come off. you have to either make or buy a custom 1" spacer so normal component speakers will fit.
kuhan
i used the stock speakers as spacers. those stock speakers are junk anyways.
useful stuff here
http://liljerk.morpheus.net/350Z/front_speakers/ http://liljerk.morpheus.net/350Z/
kuhan
might be helpful for some people.
Quote »We seem to get these questions a lot, so lets get all the information together and get this stickied to help people out.
Please post the speaker, whether you were able to fit it or not, and if so, what you needed to mount it. If you used a different method to install a speaker that is already on the list, please post also so that all options can be included in the list.
Boston AcousticsPro 6.5 - Fit over gutted stock speakersFrom: lbz
CDTES 620z - Fit with a 1" spacerFrom: ohfourzee
EF61-FG - Does not fit, Magnet does not clear window.From: Peak350
Diamond AudioS600S 6.5" - Fit over gutted stock speakers.From: Kuhan
DLSIridium - Fit with 0.5" SpacerFrom: 16psibrick
MS6A - Does not fit, Magnet does not clear window.From: sintaxeror
UP6i - Fit with 0.5" SpacerFrom: sintaxeror
FocalFocal 165 VRS - Fit with 1" spacerFrom: Roper215
Focal 165 K2P - Does not fit, Magnet does not clear window.From: Roper215
HertzHSK-163 - Fit with 1" Spacer.from:adamtaylorpcb
InfinityPerfect 6.1 - Fit with 1" spacer + 5 layers DynamatFrom: KManZ
Reference 6010cs - Fit with 1" spacerFrom: teh215
JL AudioJL audio VR 650 CSi - Fit with 0.5" spacerfrom: fatalus
MB QuartESA-216 - Fit with 1" spacerfrom: Spork
Phoenix GoldRSD65CS - Will not fit without some cutting and spacerfrom: phandango
PioneerPremier TS-D720C 6.75" - Will fit with 1" mdf spacer, or 1/2" mdf + supplied pioneer spacer.from:35oZephyR
PolkSR6500 - Fit with 1" Spacerfrom: KManZ
RainbowSLC265.25NG - Fit with 1" Spacer and included ring.from:350ZREDLINE
Rockford FosgatePunch P162S - Fit with 1" spacerFrom: sssza [/quote]
RCAnismo
Car: '06 Nissan 350Z Enthusiast, '05 CBR 1000RR Repsol, '03 Jeep Grand Cherokee
Thanks for the fitment guide. I'm definitely going to switch mine out. The stock speakers are terrible... Does the rear speakers have issues with the spacers like the front?
kuhan
^the rear doesn't need spacers, but you do not need to replace them. Just replace the front and that's enough.
I replaced front and rear, but I regretted replacing the rear ones.
_b.jaye_
Car: '03 350Z
kuhan wrote:i used the stock speakers as spacers. those stock speakers are junk anyways.
same. definately the way to go.
why werent you happy with the rear upgrade?
orangeNblue
most of the sound is distributed from the front...the back speakers could be disconnected and you wouldn't notice a sound difference
A really good set of components up front will make a huge difference and sound tremendous
_b.jaye_
Car: '03 350Z
it may not be as much sound for the money in the back, but i did 6.5 polk components all around and if i turn them off in back, its certainly a dramatic difference. granted, not as much as shutting off the front, but still a huge improvement having all four on.
shut off the rear factory ones? yeah, you may not notice. they suck, but i guarentee you, the components all around are worlds better than putting them just up front, provided you can quite the panel vibrations. probably why they put such worthless speakers back there to begin with.
Z32 TwinZ
Car: 1991 300zx TT
Im going with this setup:
- Pioneer AVIC-Z110BT- (4) Boston Acoustics Pro60 SE - (1) JL Audio 10W3v3-2- Kicker 08ZX400.1- Kicker 08ZX350.4
_b.jaye_
Car: '03 350Z
nice man. should sound damn good. im still runnin mine straight off a panasonic head unit. need to spring for a nice 4 channel, but even without, its tons better than stock.
only advice i got is to put as much thought as possible into the layout before you chop on any stock plastic. i thought i was good when i cut into the door pods for the tweeters. ended up a bit low & barely squeezed through the panel.
http://zclub.nicoclub.com/zerothread?id=372571^^mine after install^^
and if you do end up with alot of panel vibration...
http://zclub.nicoclub.com/zerothread?id=437844^^heres^^ what i ended up doin to cure alot of it. and if you wanna try any of the tape, ive still got 99.5% of that monster roll.
kuhan
orangeNblue wrote:most of the sound is distributed from the front...the back speakers could be disconnected and you wouldn't notice a sound difference
+1.
Right now, I got Alpine PDX 2.150 2-channel amp to power the front Diamond Audio S600s speakers. The rear ones (forgot the brand) are powered by the Kenwood DNX812 headunit. I got Alpine PDX 1.600 to power two JL 10w3v2s (JL stealthbox). The rear ones were overwhelmed by the fronts; therefore, replacing the rears weren't necessary and plus it's a hassle replacing the rear ones especially if it's DIY, which what I did.
_b.jaye_
Car: '03 350Z
DIY'ed my whole set-up. the rear mounting was tough, but worth it if your not afraid to modify things a bit. ill admit theres better ways to do things than i did, but it works & looks pretty good.
you dont think the reason theyre over-powered in the back is because therye a lower grade speaker powered by the head unit?
Modified by _b.jaye_ at 2:51 PM 1/4/2010
Z32 TwinZ
Car: 1991 300zx TT
do your amps over head in that glove box? also it looks like you have a amp mounting bracket...?
kuhan
Z32 TwinZ wrote:do your amps over head in that glove box? also it looks like you have a amp mounting bracket...?
overheat? Nope, I have 2 fans blowing and 1 fan underneath exhausting air (with a fan speed controller ). All these stuff are my computer parts.
no mounting bracket. I just drilled out holes in the tray and bolted down the amps. the Alpine PDX amps are stackable. If I were to do it again, I would mount the amps in the stock Bose sub location (behind driver's seat) for more air circulation.
Z32 TwinZ
Car: 1991 300zx TT
i was planning to put the subwoofer behind the driver seat. should i put it behind the passenger and the amps behind the driver?
i have a roadster
kuhan
Z32 TwinZ wrote:i was planning to put the subwoofer behind the driver seat. should i put it behind the passenger and the amps behind the driver?
i have a roadster
Does your roadster have stock Bose sub? If not, then you need a box for your sub. There is a lot of space inside the stock Bose sub location. You can mount the amp in there as well.
Z32 TwinZ
Car: 1991 300zx TT
yea i have the stock bose sytem. i was planning to just build my own box to fit in there. ive heard putting a sub in the stock bracket just sounds horrible. i have to fit 2 amps in there as well, ill have to scope it out, haven't seen inside there yet, i can only go off pictures right now.
RemixZ
Car: 2003 350z Touring & 1990 300zx NA, Past Sold 1991 NX2000 & 1999 Frontier King Cab
I’m creating a car-pc, with an ASUS T-91 touch screenGot it all working yesterday, laid out on the floor to make sure it works, then I go to install the front speakers…what do you know!!! Fak!
So… I used the speaker face plates to get the distance and took out the screens carefully (glue back in) and 3 (1-1/2” – 2”) needed for spaces for each speaker…I put the door panel back on it barely touches, but enough clearance so that the speaker doesn’t vibrate against the speaker cover…. I may place the speaker about a ¼” up and to the left, just to have peace of mind…
Today I picked up some ½” foam core board. Going to cut out a hole and stack them until I get the right height…the foam core seems pretty good for acoustics too…Or balsa wood might be better, cut some sheets up and stack them…or even maybe 4 pieces of 1-1/2” x 1” dia, dowels and drill holes and get clean set up that way too…
Bought:2x Front: JL c2-650’s2x Rear: JL x650 Co’s1x Alpine 300 4ch
Already have;Bose stock system <-replacing of course1x Kicker zx450.2 / Kicker 350.4(died a week ago)2x Sub’s 10”? with Stealth box (came with car)
bmike818
Car: 2007 Z
RemixZ wrote:I’m creating a car-pc, with an ASUS T-91 touch screenGot it all working yesterday, laid out on the floor to make sure it works, then I go to install the front speakers…what do you know!!! Fak!
hey bud, why don't you create a new thread? Do a step by step if you can, and maybe just maybe, you might get a custom title. I do want to see your setup.
RemixZ
Yeah I'll do that maybe... Check out mp3car.com that where ive been gettng ideas.
zeyn83
Car: 2008 350Z Touring
I have a Bose system on my 08 350Z and I was not happy with the head unit at all, looks ugly and very outdated. I just replaced it with a Pioneer Z110BT and I am very happy with it but it sounds just horrible with the factory Bose speakers. I played with the EQ settings etc for hours but no luck, it is not clear and not strong as I expected at all.
I was looking for a very similar setup after getting horrible sound out of my speakers. I heard Boston Acoustics speakers are really nice. Before I spend all that money I just wanted to check with you guys to see how it sounded with the setup you mentioned with
- Boston Acoustics Pro60- (1) JL Audio 10W3v3-2- Kicker 08ZX400.1- Kicker 08ZX350.4
As far as I checked online, you can get them all for $800 which is more than reasonable for this setup. I appreciate if you tell me your feedback with this setup and how happy you are with it.
Z32 TwinZ
Car: 1991 300zx TT
i have not yet installed the setup in the 350z but i do have the same setup in my twinturbo 300z except im using JL amps instead of the kicker, and im using a kenwood kvt-819 flip out screen. absolutely amazing sound! the pro60's are incredible. definitely top of the line!
i bought mine off of ebay and saved about $100 per pair
here is a link to one - http://cgi.ebay.com/PRO60SE-BO...bed80
Broadfield
Car: 1992 240sx
You guys may want to check out Hybrid Audio.... actually, you NEED to check out Hybrid Audio. I use to swear by Boston Pro's. I have been installing them for 17 years, back when they had the original Pro's. I have done probably 50 or so sets of the 6 1/2's. Then they released the Z's a few years back.... even better speaker. I was very happy with the Bostons except for their lack of mid-bass and slightly harsh tweeters.
I was then approached by Hybrid Audio two years ago to give their speakers a try.... I haven't sold any Pro's or Z's since. The Hybrids easily outperform the Bostons for even less money. At many national level IASCA and USAC events, Hybrid Audio front stage speakers are in more 1st place trophy vehicles than all other speaker manufacturers combined. Their mid-level speaker scored the highest score of any speaker ever tested at Car Audio and Electronics Magazine. Beating out competitors speakers costing literally six times as much($2000+). They now have their new entry level Imagine series available. Retail of $229..... I would stack these against the Pro's any day of the week. Now, none of the Hybrid stuff is going to have the million different mounting options like the Boston Pro's and Z's..... but who does!?! You really need to make your own baffle as thick as possible anyway to take full advantage of the Hybrid's mid-bass potential. These speakers single-handedly got me excited about car audio again.
Toby
Return to “350z / 370z Discussion”
