Upgrade sway bar?
darkblade
Car: 2007 Nissan Altima 3.5 6MT Winter Frost
Hi,
I want to know if it would be a good idea to get the RL sway bar with the stock suspension (2007 Altima 3.5SE). I don't want to drop my car because we get a lot of snow around here but I still want to get better handling. Will I get a noticable gain from the stock 3.5SE sway bar? Also would you set it to soft or stiff setting.
Thanks
Racingline
The difference even on a stock suspension will no doubt be noticeable and measurable. Weather the stiff or soft setting ( both stiffer than stock) is the right one for you depends on how you drive, where you drive and your skill level driving to compensate should you begin to oversteer in a situation and be able to keep relative control of the vehicle
