korrupt1 »
https://forums.nicoclub.com/korrupt1-u190600.html
Tue Sep 13, 2011 2:36 am
while not the same car, this is essentially the same theory.
I used to own Acura Legends religiously....some models came with Climate Controls while certain others did not. we would reguarly swap them out....yes its work, getting wiring in place, correct sensor placement...etc....but its not impossible. time consuming to be sure.
even the first gen Legends (G1's had some climate control, and dictated what year and trim level you had...G2's (91-95) also were the same in this respect)
thing about undertaking that sort of project is to know your time frame, have it all laid out before you prior to tearing into your car.....best bet would be to find a car in local yard...get all the parts you will need....research these BEFORE going to yard because invariably some idiot will take that one piece you wind up needing that you didnt know you needed....time your project to coincide with the weather as much as possible...doing something to this degree in the beginning of summer...and you will be cursing yourself to death because of it. same with winter (if its any where near cold where you live....I live in AZ so its pretty much always like being in Satans basement)....
plan plan plan!!!!!! then execute.
