"Upgrade" 94 Q45 from Fed to CA Emissions
skylimey
Having just brought a beautiful '94 from IL to CA, I'll need to get it smogged. The emissions label doesn't say CA, so I'm guessing there's gonna be some $$$ involved to get it to pass CA emissions.
Any thoughts on how best to go about this? Selling the car out of state is not my preferred solution.
Thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Try a dry run first. Only difference was one (I think) temperature sensor, maybe a little different program in ECM.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
WIthout the extra temp sensor in the engine, i dont think it will make any difference.. main difference was the cats...
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
If it's a Fed car, it goes through the computer as a fed car when your vin is scanned. There's no need to change anything unless it doesn't pass. If you want to reassure yourself you can always do a pretest. But we used to have cars from Canada coming in and passing smog. It'll be ok as long as it's not excessively modified and it burns clean.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
You shouldn't need to do anything to swap it over, just get it smog checked and if it passes you're in. If it doesn't pass, it's because of a bad injector or plugs and you'll just need to fix the malfunction. I brought a 90 Q here from TX and it was not at all a problem.
skylimey
Gents, Thanks. Thats a relief.
I'll let ya'll know.
Martin
RobertsnewQ
Yes, the old laws made you pay $300 if it did not have a CA sticker, but that was made invalid in the courts.
Now if it passes the sniffer you're good.
