HamsterDR »
https://forums.nicoclub.com/hamsterdr-u197870.html
Sun Apr 15, 2012 1:51 pm
I ran the update - and it did take more than 90 minutes to complete. Everything went fine and the system is working. I'll see over the next week whether some of the map problems have been fixed. Strangely, after I had started the update, I noticed that the receipt said "2009-2010 Brazilian Navigation Software". All the DVDs and the box say North America, and label it as Map X9 - DVD Year 2012.
A couple of tips: Blue Tooth has to be turned off to install the software, but the instructions didn't match what my system showed. Also, you have to check to make sure that the software has a higher version number than what is installed. The instructions say to check the five-digit version number to make sure it is the same or "higher" than the existing version. However, the new five-digit version number starts with an alpha character ("A"). Since my car is a 2010 probably built in mid-2010 I figured the new software should be installed, and I didn't have any problems.
It's expensive, and a lot to go through to get this updated.
David
