spooled240 wrote:very nicely done!!!!I also see you got the k's bumper. You gonna do the whole k's aero?
what kind of wheels are those and what offset/width/diameter? they look nice man..that whole car looks mint
Thanks for all the compliments/encouragements.
I apologize to being a traitor to zenkis, but let's be serious here, kouki's just look more bad-***...far more aggressive front fascia. I love the zenki but I've always lusted after a kouki front end, and well, i'm human
I'm understandably broke right now, but yes I'd definitely like to at least pick up some side skirts, but that'd be minimum $400 with paint...
I'm an hour and a half from boston, and i've been on 240sxone forums before....IIRC, that's where I found the parts for the kouki conversion...
Wheels are 16 x 8" CCW (complete custom wheel, but this set was actually manufactured by Bogart Racing wheels). 2 piece, welded, forged shells, CNC'd centers...+10 mm offset rear, +16 mm front.
I dont know who asked it but I was never considering putting a V8 in it lol. It'd destroy the weight distribution. Besides, 343 rwhp is plenty for me now, that's about 400 crank.
For those too lazy to navigate my website, here's the full specs. I tried to keep it sleeper and stock looking...
Engine/Transmission :
-Turbo240/Garrett GT32 Turbo, .63 a/r turbine, .60 a/r compressor, 15 psi -Log manifold, ceramic coated, flange cut between individual runners to prevent cracking -2.5 inch mandrel bent steel downpipe w/flex pipe; no catalytic converter or resonator, tanabe hyper medalion exhaust the rest of the way -2.5 inch mandrel bent stainless steel turbo inlet JGS tools 26 inch x 8 inch x 3 inch tube and fin aluminum intercooler 2 inch aluminum hot-side piping, 2.5 inch aluminum cold-side, mandrel-bent Tanabe Hyper Medalion stainless steel exhaust Multi-ply high temp, high pressure silicone and stainless clamps used throughout K&N cone air filter Alcohol injection programmed to come on at 6.75 psi Northern Tools and Equipment 1.0 gpm alcohol injection pump Callaway turbo alcohol injection nozzle Walbro 255 lph high-pressure fuel pump MSD top-feed saturated 50 lb/hr (525 cc/min) fuel injectors, balanced and blueprinted Aeromotive adjustable fuel pressure regulator (34 psi @ idle) JWT Turbo ECU, for MSD 50 lb fuel injectors and Cobra MAFS Aurora 8 mm plug wires NGK Iridium IX spark plugs (BKR7EIX-11) PDM-Racing Stage II S14 camshafts/shims Front-mount oil cooler, thermostatically controlled Koyo 2.1 inch all-aluminum polished radiator Turbo XS Engineering bypass valve Ford Cobra MAFS (1993). 3.5 inch inlet, 3 inch outlet Turbo240 billet aluminum top-feed fuel rail, 3/8
Suspension/Brakes/Wheels/Transmission :
Front: SPL Parts/KTS coilovers, 8kg springs, 40 mm diameter piston, inverted shock design, adjustable ride height, spring preload, camber, 15 way dampening adjustment Rear: SPL Parts/KTS coilovers, 6kg springs, 49 mm diameter piston, pillowball mounts, adjustable ride height, spring preload and 15 way dampening adjustment Pilot front strut tower brace Cusco rear strut tower brace Suspension Techniques anti-sway bars front/rear with polyurethane bushings Project Silvia tension rods w/spherical bearings and dust-boots Nismo subframe power-brace KVR cross-drilled, vented, and cadmium plated brake rotors on all four corners KVR carbon-kevlar brake pads on all four corners Custom 16 inch by 8 inch Bogart two-piece welded, fully forged rims with spun shells, +10 mm offset rear, +16 mm offset front. Kumho Ecsta MX 225/50/16 Z-rated tires up front Yokohama 245/45/16 Z-rated tires out back Adjustable pillowball billet mounts for coilovers SPL parts subframe-bushing collars SPL parts stainless steel braided brake lines; teflon lined and coated Speed Bleeders Fidanza Aluminum Flywheel ACT Street Clutch B&M Short-Shifter; Redline MT-90 synthetic transmission fluid ASP Aluminum Crank Pulley
Miscellaneous :
emerald blue, originally zenkiAutometer boost gauge/alc injection light Zeitronix ZT-2 Wideband 02 monitoring system Kouki front end with JDM K's front bumperJDM zenki turn signals (amber) SE mud-flaps Battery relocated to trunk Some crappy Aiwa head-unit Custom engine torque-dampener Semi-gutted rear interior Leather shift-boot Upper timing chain guides removed (no slapping sound!) CNC drilled aluminum clutch/brake/accelerator pedals. 2.5 inch electronic exhaust cut-out that makes the exhaust effectively just the downpipe, activated via a switch in the cabin
