Are the ECU's available yet? I need one for a 94Q Activeelwesso wrote:sometime in september or october. I will announce when they are back up
you could do it but we're not going to design it so..... Youll have to modify that yourself.chomer wrote:Are the NICO ECU's still available? And (I haven't check the wiring diagrams), but would it be possible to use the seat heater switches or TCS switches to control the program that is being run?
We've concluded it cant be done....TXCumtrensh wrote:Im with alot of people, PLEASE start researching 97+ Y33 ecu's!
We need a hookup too!
Wes, I already told Robert, but i have a '90 core that i will donate.elwesso wrote:we're going to make another run on ECUs... Right now the way im doing it is I have to find a bunch of cores.... So if you guys have spare core ECUs we can work out a deal.....
Pricing is going to be a bit more expensive mainly because we arent doing them in as much quantity as we did last time.. My plan is to just have the ECU's handy, and then when someone wants one it'll already be ready.
There has been some sucess, search for a few threads in Infiniti Online Mechanicponzy wrote:and.......can an aftermarket radiator for q45 provide a good working cooling system?
maxnix wrote:So, since I don't recall.....does Robert always remove the top speed limiter from all his ECU?
