HolyShiznit »
https://forums.nicoclub.com/holyshiznit-u7729.html
Sun Jul 24, 2005 6:45 am
Well as you know I have another topic explaining the problems. It was VERY unorthodox and I HIGHLY doubt that anyone else in the community will EVER have my problem but it's fixed now.
My question is for those using a JWT and SAFC II (I feel your pain), what are your SAFC in and out settings. I have mine at 2in 5out because it seemed to idle the best but whenever I go into boost it's pig rich. I have the SAFC at -10% and I am worried that it's just on the wrong settings. 2in 2out makes it extremely lean at idle like 17.1 and if I rev it up it stays pretty lean so I really don't want to risk that in boost. Should I just keep the 2in 5out setting and continue tuning out the richness?
I have 75lb injectors but the program is for 72, so maybe it's running uber JWT richness + bigger injectors? *shrug*
It should be noted that while I am putzing around and tuning my timign isn't perfect. It's at 16 degrees base right now. Could the 4 degrees retarded be causing extra richness? Just a thought.
