Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Nov 04, 2004 11:19 pm
Only if you had to replace everything could it cost $5,000! Why we buy junk Q for parts. However we use new TCS aux TPS and throttle motors.
The buzzing was probably the TCS auxillary pressure pump coming on.Since TCS applies rear brakes, the TCS must have an accumulation of brake fluid pressure to use since driver doesn't apply the brakes.The whole TCS circuit is after the ABS rear line which is then split into two paths , one for each rear brake caliper.
The reason the under battery relays get replaced is usually battery acid over flow from a cracked retainer tray caused by an improper aftermarket battery [wrong physical size] and the installtion of same flopping around [improperly restrained].
You must read the REAL TCS code via the Consult to start the diagnostic proceedure............usually a bad wheel sensor, bad aux TPS, bad aux motor.Probably less than $1500 [worst case] to repair assuming a mix of used and new parts.
