beans33 wrote:Hey dee I did that and its giving me 21 and 43. 21 says its a ignition missing in primary coil. If you could help me with that one it would help.. what to do ? 43 is tps Im not really sure what to do about that. I have a ka throttle body with a CA tps and i put it on .46.. thanks
Have you inspected the ecu plug wires to make sure that any of them aren't disconnected or damaged? Do you have the wires hooked-up correctly out by the battery? Do you have the orange wire hooked-up at the dash connector. Your problem mor than likely lies within the wiring job as stated above.
A busted AFM is just that and they don't self repair; and besides, if it was really screwed-up, you'll be seeing that code 34 as well. Now that they are gone, triple check your wiring. Don't be afraid to pull the harness back out to look it over. I have found that 95% of the problems that members have with their CA swaps on this forum is because they did or had someone do bad wiring job.
Dee
