UPDATE:
the other night it got really cool here in Texas and the car ran like it did before all this mess. and when it was that cool i want to guess 60* it ran fine all the way past engine warn up and everything. Fast as balls, and i remembered what ive been missing about my car.
its something heat related, like the motor is pulling timing to warn off detonation. ive noticed the "raw" knock sensor numbers on the safc2 to be considerably higher -at idle- when the motor is acting up.
since the MAF is on the hotter side of the motor, has anyone had issues with the turbo heat messing with the MAF?
something heat related......
and i checked the MAF,i swapped in a friends z32 MAF and changed the IN/OUT safc setting numbers to the correct values, and at first it ran fine but still warmer weather temps make the car bog.[ 04in 04out is stock s2 rb25, the correction code is 02in for a z32 maf]
link to original thread with symptoms
zerothread/332138
