Update on the current status!
Abdo
Car: S13 RB25DET
Since my build status thread I've installed:STANCE GR+ PRO coiloversMeganRacing RUCAsCircuit Sports hood dampers
I will soon be installing:SPORTMAX 962's (18x7.5 FR, 18x9.5 RR)Oil cooler
Just thought I would fill you guys in!
mello88
Car: s13
cool... but... not even one picture of the engine bay
Abdo
Car: S13 RB25DET
I don't have any recent pictures of the engine bay, I'll take one tonight.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
What is with the dangling toy on the pass-rear tow hook (opposite exhaust)?
Shocker
Car: 89 240sxHB rb26/30
l0nestar wrote:What is with the dangling toy on the pass-rear tow hook (opposite exhaust)?
gay trend....
Abdo
Car: S13 RB25DET
It's Mario man..
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
mello88 wrote:not even one picture of the engine bay
+1
Abdo
Car: S13 RB25DET
mello88 wrote:cool... but... not even one picture of the engine bay
I just took this a second ago, and I know it's really dirty.
Cjmartz2k
Car: Hunting for a '89 GTR now
Shocker wrote:
gay trend....
All the Japanese used to do that here like 5 years ago, so I guess it's just making it's way to the states.
Shocker
Cjmartz2k wrote:All the Japanese used to do that here like 5 years ago, so I guess it's just making it's way to the states.
Yeah I'm aware, but my opinion still stands.
Engine bay looks nice!
Neejay
Good job man, looks clean.
2 questions:
1. How are those hood dampers? I was looking into getting a set2. What size and brand FMIC is that where you didn't have to chop/lose the front bumper support?
Cjmartz2k
Oh, I agree with you also
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Another catch can setup gone wrong...please search on how to connect that before the rings get damaged.
Otherwise, looks dirty but good!
l0nestar
2004 Toyota Altezza
Darius wrote:Another catch can setup gone wrong...
Oh noes! Not another catch tank thread!
Darius
It is like the movie Groundhog's Day with that damn topic! Never ending.
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
The jury is still out on the best way to connect those damn things .
Abdo
Car: S13 RB25DET
Thanks. The hood dampers work great, http://www.optionimports.com/cisphodas13s.htmlThe intercooler is 12”x24”x3”, although I did have to modify the area a lot to make room.
Darius, I read that thread on how to connect the catch tank, and although it’s hard to see it clearly in the picture, there is a third nipple on the valve cover that I have reserved as a breather. Should I route that breather back into the intake?
Darius
Yes but everyone agrees that it needs some kind of vent or the crank case will pressurize under boost. Bye bye rings.
From the pic Abdo posted, it looks like he is running one valve cover to each of the Greddy catch can barbed fittings. With this setup, there is no venting. I'm surprised this thing doesn't blow major blue smoke when you drive it. At idle it should be fine since the stock PCV valve is in place and probably connected into the IM.
If you put a vent on the vertical fitting on the exhaust valve cover, the catch can will do nothing because the air will most likely go through the breather filter and not the can.
The breather filter should go on the catch. Then, the valve covers get connected and one line runs to the remaining barbed fitting on the can from the vertical fitting on the exhaust valve cover. If you want to recirc it back into the intake tract and get vacuum on the crank case, remove the breather filter and run a line from there to the intake. Simple as that.
Shocker
Heres what I personally feel is the best way. Keeps a CONSTANT vac on your crank case escaping the gases, and prevents oil from entering charge pipes/intake under boost. Catch can must be sealed (no vent) for this to work properly.
my badass paint of it.
Neejay
What about with the PCV still in place?
Shocker
Neejay wrote:What about with the PCV still in place?
Then it would still need to be hooked up to the intake plenum like it is factory. My plenum doesn't allow for it. So blocking it does just the trick.
Darius
Yep I agree with Shocker. Nice paint btw. I suck at drawing with the mouse. Looks like a 3 yr old drew it with a crayon.
PCV valve might actually keep the intake and intercooler piping a little cleaner if it was kept in use. I just left it in the valve cover and blocked it off for the same reason stated by Shocker.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Darius wrote:Yep I agree with Shocker. Nice paint btw. I suck at drawing with the mouse. Looks like a 3 yr old drew it with a crayon.
That is the best way to run it. Not using the PCV valve and running a catch can allows for alot more moisture to be caught in the can.
Abdo
Car: S13 RB25DET
Just thought I would post this picture of the rear 962's installed..
I wanted 275's, but they were unavailable to me at the time so I settled with 255/35/18.
wheel sizes:18x7.5 fr18x9.5 rr
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
hey abdo. Whatever anyone says about your drift buddy. Don't worry about it. I've seen most of the drifters here with them on all kinds of cars. lol. I just saw a crashed r32 today with a drift buddy. But he did have a wakabi leaf on his car.
Abdo
Car: S13 RB25DET
lol, its more of a joke than anything. plus super mario is the ****, and no one can argue with that. I mean, how often do you see plumbers ****ing princesses? exactly.
Abdo
Car: S13 RB25DET
Did a few things to the ride today, thought I would share..
So I finally installed the front wheels, lol
Somewhere in Texas (summer vaca)
Redoing the IC setup..
Skyview of Tulsa (on the way back)
Also redid the radiator fan setup, installed a neat thermostatic switch that Jesse made for me :D
Coming up next weekend: I'll hopefully have the J30 LSD from Ken/Brandon installed, along with finishing up some IC issues.
Abdo
Car: S13 RB25DET
INITIAL STARTUP - MARCH 9TH, 2008http://www.youtube.com/watch?v=zR2Q7N3eZTs
REVVING AWAY LAST SUNDAY - SEPTEMPER 7TH, 2008http://www.youtube.com/watch?v=wvyOH8jhOVI
I redid the intercooler setup, still not fully satisfied with it, but atleast now its mounted somewhat properly using titanium brackets bolted to the front bumper support. J30 LSD coming in next weekend, but i will need to buy the J30 half shafts to install.. If you have some laying around holler at me. If I can get enough studying done tomorrow morning I'll try to fix the exhaust leak and install the missing front passengerside sway bar end link bushing. The car is making loud popping noises towards the passenger side when I steer at a stop or go over speed bumps, so I'll have to check out the ball joints as well. Also it's a good time for me to get an alignment and the ruca's adjusted so that i wont have any more camber issues. As soon as I sort out all of these small problems I should be starting on paint and body. The only thing that makes it so hard is that school is getting in the way of my automobile addiction, and we all know which is more important. :-P
http://www.youtube.com/watch?v=1KGYJazSJVEHere is a video of me, Dave with his S13 SR20, and Nik with his S14 RB20 cruising down riverside in Tulsa last Friday night. Enjoy!
Modified by Abdo at 7:53 AM 9/22/2008
