elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Nov 02, 2004 2:10 pm
Like I said in the other thread, I spoke with Rex yesterday... I also spoke with Ben at JWT, as well as Sam at LevelTen..... I will get into that later....
First, I am still trying to get my nitrous going... However, I am having a hard time diagnosing why the nitrous is coming on before the ECU says so. Ben said that (like everyone else said, not doubting anyone) that somewhere there is a switch that allows power to get to the solenoid, bypassing what hte ECU has to say... I took stuff apart today by the ECU, and traced some wires..... And I can see where the arming system goes into the ECU... From this point, nothing looks out of the ordinary... I will get some pictures when its light out, because I dont really know much about this. Ben also said that the correct jet is (IIRC off memory) is .053, but that could be wrong. Im pretty sure that Rex didnt mess with that too much, as when he added the (150 shot) wet setup, that worked independent of the dry JWT...
I think the system will work fine and safely, but I dont want to roast the tires, and also, im afraid the system will spray through the shifts if it does this.. However they say the transmission is good for 1000hp, i wouldnt assume that would apply to shifting WHILE under that...
Also, regarding the transmission, I had a slow shift from 2-3... Especially when cold... Sam at Level10 said that because of the higher stall rate, the 2-3 is going to shift slower.. Dont know why that would ONLY affect the 2-3 shift... But whatever the case is, he seemed to think it wasnt that big of a deal, and that i should just replace the fluid/filter. I think with the external transmission cooler I gotta let the car warm up more, as lately its only been about 1-2 mins... And probably doesnt get to 176F I dont know how fred did this, but I would assume it was about the same. FYI- Level 10 DOES NOT recommend flushing the system. They recommend redline transmission fluid (which is what Ill replace it with) every 30k (im at about 33k), and to drain the pan, and replace the filter. HE said just replace whats in the pan, youll be good for another 30k. I may do the Dennis recommended "home brew" flush by waiting 2 mins (my ATF pump is High Performance, i wonder how much difference hte flow rate is)...
So thats where Im at now.. Im workin on buyin the drag wheels that rex had on the Q...
