Bwana »
https://forums.nicoclub.com/bwana-u19793.html
Tue Oct 25, 2005 12:28 pm
Here are a couple pics showing where I'm at on my MGB/CA18DET swap.
The top one shows my oil pan/crossmember issue. Question: Are there any versions of the CA18 that use a rear sump oil pan? If not I'll fab one up, but it'd be easier to just swap it.
The second pic shows my driver side clearance with manifold/turbo removed. There's no way the turbo is going to work in the stock location, so I guess I'll be fabbing a manifold for that . I can't go top mount for hood clearance reasons, but I have plenty of room up toward the front since I don't have any A/C or P/S, and lots of fender room (no strut towers in these cars). Question: Where can I get a DIY manifold kit for this engine?
As far as I know, this is the first time anyone has put a CA in a MGB so I'm trying to document my work somewhat (kinda bad at that sorta thing). I know you guys are Nissan guys, I hope you don't mind! I'll try to keep you updated on the project, and will definately be bugging you for info on this drivetrain.
