rbspitfire »
https://forums.nicoclub.com/rbspitfire-u44060.html
Sun Nov 19, 2006 4:30 pm
ok, it still isnt fixed, but have come to the conclusion that its the ecu. the engine temp sensor tested ok, the MAF is sending a signals that its suppsoed to, the CAS is obviously working since it does run. the only thaing that has improved is the cold start problem, just had to wire the engine start signal. but the ecu still just blinks (not codes) just blinks. i havent figured out how to pull codes?? the only thing ive found on how to do it is to turn the screw on the ecu all the way CCW, but that didnt do anything. oh yeah i even took apart the ecu looking for some sort of visual sign of it being fried and found nothing? i am completely stumped?? i have made sure that all sensors signals are making it all the way to the ecu, tps, maf, engine temp...i would say that its running like the maf is unplugged but from what ive read if you unplug the maf it will try to kill the car, its acting like if the tps is unplugged when you try to set timing, when i unplug the tps, maf, engine temp it diesnt skip a beat? sorry its so long but im really confused , i have searched and found little from people who have been in safe mose, if i do find some they never say what cured it.
