Coolwhip wrote:i love it, by the the way are you gonna be using a timing belt cover uptop?
Thanks alot for the comment Darius...I do remember you from 240sxforum I believe. I just like to do things right the first time and make it look as clean as I can, even if that means a little more time and money. How is yours doing?Darius wrote:That thing looks incredible. I've always looked up to you on the web boards for ideas because you're so damn thorough. It's good to have people like you on here that take their time and aren't too anxious to get the thing swapped in. Okay I'm done kissing ***, but that those pictures are probably the best I've seen next to ones of the RB26 going into a 280Z with custom twin turbo exhaust manifold. Continue to keep us posted!
I hope to have around 500-600hp for now until I upgrade the turbo, exhuast manifold and a few other small things. I am well aware things don't always go as planned so that is why I say Hope....lol. PSI probably will be around 23psi+ on the 61mm turbo.midnightsliding wrote:looks great , good build how muh power are u looking to make? and how much PSI are u goign to run? hope the tuning comes along well.
Wow....i agree, looks good!...and I'm also going the same route, I'll be doing the same this winter. here's my mods.(pretty close.....lol)....some of the stuff I have on the car and some of it is in my garage.Kansei240sx wrote:That is EFFIN sweet my friend! Makes me glad i took a similar route with my motor as well, as far as the stripping down the engine and cleaning it up and replacing everything on it minus the turbo and exhuast manifold.
I am actually going to be running the Mega Squirt with the EDIS6 setup for the ignition. It is very easy to use and works just as good as the other average stand alones for only $350-400.Reignman wrote:Its looking good! Very clean! What engine management will you be using?
Yeah I am running stock cams...nothing on the head has been touched for now. When I throw some cams in the whole valve train will be built with it.Phat_Optimo wrote:Stock cams?Everything else looks good though.
Manifold cost me $60 to ceramic coat it, turbine I am not sure of yet....since I have not done that just yet.Need2Boost wrote:Looks good. How much did you pay for the manifold and turbine coating? Thanks
That's a nice setup. You will have to let me know how it all goes. I am going to see how well this setup of mine interacts with the tuning and if it needs more then I will be upgrading probably to a larger 60mm series turbo or might go GT40/42.Sky240PWR wrote:Wow....i agree, looks good!...and I'm also going the same route, I'll be doing the same this winter. here's my mods.(pretty close.....lol)....some of the stuff I have on the car and some of it is in my garage.
RB25DET SII motor APR rod boltsARP head studs ARP main bolts Greddy 1.1mm head gasket ------on car nowported & polished headGude racing camsT67 81trim Turbo (Precision) HKS external wastegate Custom intercooler piping------on car nowDual pusher fans(altima) Greddy Fuel rail1000cc injectors(on the way) Q45 Throttle body(polished)------on car nowGreddy Intake manifold (polished)------on car nowGreddy timing belt------on car nowGreddy FMIC ------on car nowKoyo radiator------on car nowHKS exhuast manifoldOil overflow catch canOverflow coolant tank Megan test pipe------on car nowTanabe racing exhuast ------on car now3'' downpipe ------on car now
my list isn't as big as yours but I'm still in the process of getting stuff i need!Modified by Sky240PWR at 5:57 PM 1/22/2006
