brc19761 »
https://forums.nicoclub.com/brc19761-u245639.html
Fri Jan 23, 2015 7:26 pm
I have posted on this problem, as you can see in my recent posts. I have a 2008 Nissan Pathfinder 2wd. Around Christmas the service engine soon light came on. My ob2 scanner came back with a P0455 which was gross fuel evaporation leak. Well the wonderful people on this site I was given great information and advice,
First I replaced the gas cap with a new one from Autozone well that didn't solve the issue. Next I purchased a OEM gas cap from my local Nissan dealership that didn't fix it either. I studied the fsm on the EVAP problems and received much information from this website.
This Thursday I took the canister, all hoses, and the vent valve solenoid apart. Inspected all hoses and no cracks. I tested the vent valve solenoid, but I didn't get a clicking noise. I didn't really know what I was suppose to hear, if anything at all. I checked the spring and plunger and even moved the plunger manually. The vent valve solenoid was $70.00 at Autozone. I didn't know if the solenoid was good or bad and didn't want to waste my money not knowing. I put everything back together.
Next I took the purge valve solenoid (which is located on the engine) off. I tested it and it would make a loud clicking noise. I started the Pathfinder up to make sure everything was working and then cleared the code. I got up the next morning and immediately the check engine light soon came on. I got the ob2 scanner and it read a new code (only the one code). The code was P0447 which is Evaporation Emission Vent System Control Circuit Open. I cleared the code and started the vehicle up and immediately the light came on with the same code. I went and checked the wiring harness was secure on the vent valve solenoid (it was secure). I drove the Pathfinder to town and back and it ran fine.
I was thinking since I moved the vent valve solenoid by hand that maybe it was stuck and moving it caused it to unseal and the solenoid was not working. Does that seem logical? Do I need a new vent valve solenoid? The only thing that is throwing me for a loop is the code saying the circuit was open. I checked the fsm and really couldn't decide what to do.
Any comments would be greatly appreciated. Your advice has been priceless so far.
Thanks,
brc
